Pine tar sap
13
Catalina capri 18 Chapel Hill, NC
I noticed tiny black spots on the boat. They are coming from pine trees in the yard. Any suggestions on how to remove and not damage gel coat or decking.
Thanks!
wetass
Mar 9, 2011
190
CS 36T Seattle
You thin pine tar for coating wood with turpentine or sometimes mineral spirits, so you may want to give that a try - I'd start with mineral spirits though.
jrowan
Mar 5, 2011
1,294
I have owned older sailboats for a few decades and I would not use any type of oil or petroleum based cleaner to remove tree sap. The oils in stuff like WD 40 will create their own stains in an older porous gelcoat surface, and are even tougher to remove. I and my dad who sailed for twice as long as me swear by using "Soft Scrub" type fiberglass bathtub cleaner with bleach. It works miracles at removing stains on old gelcoat. If the stain is really tenacious, use a green sided scrubby sponge with the soft scrub. If that doesn't get the stain out, nothin will!
Sylvan
Oct 11, 2010
31
Catalina 22 Pinedale, WY
Pine Sap Removal
If Sofscrub doesn't work, mix it with rubbing alcohol. RK
