Sinnettc brings up an interesting point on the subject of pinching. A lot of sailors complain to me that their boat doesn't point high enough. My answer is "so what" and then I go on to explain my reasoning. When you are pointing you are sailing closer to your destinatation but slower than if you foot off a bit to where you'rere sailing farther to your destination but faster. With two matched boats sailing head to head, one pointing as high as he can and the other footing off a bit, the footed off boat will eventually overtake and pass the pointed boat.
The biggest problem with trying to point as high as you can is called PINCHING. That is where you are pushing the pointing ability of your boat to the absolute max and you are within inches of stalling both the main and jib.
Next time you're on the water check out what I'm saying and you'll see what I mean.
