Tons of Information
"Pimples", imply to me that you probably have a blister problem; however, that cannot be confirmed without hauling the vessel out for a thorough inspection whereby you have to pressure wash the bottom for a good look. You did not elaborate Bill on the quantity and how big some may be. Osmotic blistering is more common in fresh water then salt due to the differences in density coupled with temperature. Their is a plethera of information on the subject, but depending on the number and locations, you should attend to them at your earliest convenience. When I hauled my 1984 Hunter 25 several years ago before I bought my 1988 Catalina 30, I counted over 800 blisters ranging from small nail head size to a half-dollar. I read up on the subject, bought a grinder and proceeded to go to work, successfully repairing the damage, painting the bottom and selling the boat. It was not a fun experience, but hanging out in the do-it-yourself yard and witnessing others repairing the same, the information sharing added to the success of the repairs. I think blisters though are often overrated. Their are many who are of that school that feel the damage never gets that extensive as to sink a vessel by a complete break-thru. Its only when the blisters beocme so abundant and form an extensive mat type pattern where gelcoat peeling is required, which can be very expensive and time consuming. I understand that barrier coats as well are not absolute insurance for blister prevention. When I hauled my 30 last July I repaired seven small blisters and applied three coats of ablative paint. I feel the secret to prevention on blisters is to inspect and repaint every two - three years or as necessary as long as the boat remains in fresh water. If your handy, the physical repair of a blister itself is quite simple. The most difficult part I thought was the application of the fiberglass filler as once its cure's its a tough one to sand and fair. RegardsBob
