phrf ratings
1
ericson 35-2 PENTICTON
does anyone know the phrf rating for a 1976 ericson 35-2
has a 150 genny
non folding prop
and we run spinnaker
thnx
criag
Rick D
Jun 14, 2008
7,190
PHRF ratings vary by region. Your regional PHRF should have a website with a list of boats which you can review to find something similar, but to obtain a rating, you need to join the fleet and provide them the specifics of your boat.
Have fun!
Apr 8, 2010
2,167
has a 150 genny
non folding prop
thnx
criag
Craig, You need to "Uncloak" a bit and fill out your bio here. Location is important in many instances when folks ask questions here, and this is one of 'em.
Also, ask your question at your owners' site at ericsonyachts.org. Lots of sister ship owers log in regularly there.
May 12, 2008
24
Santana 525 Bristol, PA Delaware River
US Sailing PHRF Baseline Ratings
Check out this link to baseline ratings for most production boats.
http://offshore.ussailing.org/Assets/Offshore/PHRF/Hi+Lo+Mean+Report+September+19+2011.pdf
This resource is helpful to get you close to your rating but you need to go to your local PHRF organization, provide measurements and complete your application. They will assign you an accurate local rating.
http://offshore.ussailing.org/PHRF.htm This link is the home for PHRF and should help you. My boat rates a 192 at PHRF-CB and an even lower 186 in PHRF-MA but in PHRF NW a 201. Go figure.
Good luck.
May 24, 2007
185
Beneteau 352 Milwaukee, WI
Location is eveything
As others have indicated, there will be a local governing body that will issue the PHRF for your boat in the area you race and they oversee.
If you raced on Lake Michigan, you would likely have a base rating of 159, with spinnaker, and 171 without. This assumes the 150 genny is the standard foresail for your boat. The non-folding prop may give you a couple extra points too.
