Chris has it, We needed our side fixed ports to have a bow. I laid them on Blocks, boiled water and wrapped towels around the plexi then kept pouring boiling hot water on the towels. Then put a weight in the middle to hold it down. Let it all kool then checked for fit. You'll probably need to bend past flat just a little so when you remove the weight it will spring back a little to flat.
Good thing with this method is you can do it as many times as needed to get it right without screwing up the plexe.
Good luck.
