I HAVE THE SOLUTION
FIRST YOU SHOP AROUND FOR AN OLD STEEL BASKET, THE SIZE OF A WOOD SKID, THE TYPE THEY USE FOR STORING JUNK MAT'L, AND CAN FOLD, TIE SOME FLOATS ON IT SO IT CAN'T SINK, TAKE IT OUT TO THE RIGHT SPOT, SECURE A 10' PC OF 3/8" CHAIN TO THE CENTER OF THE BOTTOM, AND EACH DAY, YOU LOOKFOR STEEL JUNK, SMALL ENGINE, CRANKS, CASTING, AND EACH DAY YOU FILL A COUPLE OF BUCKETS, AND DUMP THEM INTO THE BASKET, BY THE WAY START WITH YOUR CHAPMAN BOOK, IT'S JUNK, WHEN YOU FILL THE BASKET, THEN IT'S TIME TO BRING OUT A BAG OR TWO OF CEMENT, EACH DAY AND LINE THE SIDES OF THE BASKET WITH THE BAGS OF CEMENT, THE WATER WILL PENETRATE THE PAPER, THE CEMENT WILL HARDEN, THE PAPER WILL DESOLVE, THEN TOP THE WHOLE THING WITH CEMENT BAGSA, BUT CUT OPEN, TO FORM ONE HEAVY MOTHER OF A MOORING ANCHOR.
