- Oct 22, 2014
- 23,162
I have a 4107 with a bad coolant pump. I removed the pump and have ordered a replacement. I've been told the replacement does not have a back plate or a pulley installed.
So I understand I need to remove the Pulley and use it and the back plate on the new unit.
I have the back plate removed and have brushed the rust (mostly) off the plate. I see where the impeller gouged the surface of the plate (Pictures attached).
Do I need to buff and smooth the plate before reusing?
I know I have to gasket both sides of the plate when installing. Do you use a dressing/adhesive to attach the gasket to the metal plate?
Thanks for your help.
