Perkins 4-108 in a 10,000 lb. boat
2,288
C30 Event Horizon Port Aransas
I am considering the purchase of a Perkins 4-108 right now. I want to put it in my C30. Is this overwhelming for my boat? I wouldn't mind having to modify the engine compartment to have that much horsepower. I think it is a 50 hp, but I am not sure. It's a bit of a drive for me to put my eyes on this engine so I can't guesstimate it's size compared to what is in my boat now. Does it use a 1" shaft?
Is this just way out of the question or is it reasonable?
Ross
Jun 15, 2004
14,693
My ten HP engine will push my Islander 30 (about 9500 pounds) to about 5.5 knots with no complaints after that I just start digging a hole in the river and at about six kts my cockpit drains back flood.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
C'mon Hermit...get the lead out...you can't afford a new roller furler, but you can afford to put a ridiculously large engine in? It's a sailboat!
BobM
Jun 10, 2004
3,269
Ah ha...
...I hadn't seen your about low oil pressure yet. Apologies! I'd still fix the furler if the engine is running okay. Then keep you eyes open for a spare engine. Plenty of people repower and remove these 1 cyl yanmars.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
4-108
Hermit,
The 4-108 is a beast. Big, and heavy. I don't know if there is any way you could shoe horn that thing in the space where a one lunger was, but IMHO it is far to heavy for any 30 footer. Of course, if you can get it in there, can probably water ski behind it.
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
I also think it's too much engine. Not because of the power, because you can have a motor sailor if you want to; but with that much weight, your tail is going to be dragging big time. The sailing performance will suffer.
Joe S
615
Morgan 415 Out Island Rogersville, AL
Generaly speaking, the more the cylinders the smoother the engine runs. Also, raw horespower is nice for pushing through waves and wind. However, pay attention to whether the engine would sink the boat below the designed waterline. Larger engines also consume more fuel, requiring larger fuel tanks. Sailing is one big compromise.
Feb 6, 1998
11,772
Hermit
Hermit that engine would be unnecessarily large for the C-30 and you'd most likely never be able to run it at 80% thus not utilizing the potential. The main reason this won't work well is SPACE. The C-30 requires a low engine to fit under the cabinet and settee and it also can't be very long altogether. The 4-108 is quite large. I installed a Universal M3 20B in mine and I know the M25's fit as well. Even then we still ahd to make some height modifications to galley cabinet for the exhaust riser. 15- 23 hp is more than enough for a C30.
Heck there are still many C-30's with the one lunger doing just fine, when the prop is right. Make sure your current engine can turn max rated RPM with a clean bottom & prop. If you can't get your engine to MAX rated RPM or it gets there too easily or goes above it the prop needs addressing.
The MAX RPM on our boat is 3000 RPM and the engine gets to 2980 as measured with a digital photo tach. It took two tries with the prop manufacturer to get this just right. The first one came in 270 RPM to low. The second one is just about perfect and only off by 20 RPM which is about as good as it gets. Your engine should be able to deliver MAX RPM no more no less within 50 - 75 RPM for the best results.
zeehag
Mar 26, 2009
3,198
having just muscled into my formosa a beautiful and HUGE perkins 4-108, i would say--please fix the engine you already have or find a small yanmar--2 cyl work fine--i have one in my ericson 35---there is NOT enough room in your engine room for al the misc bs a 4-108 needs to have for complete installation, nor is there any room for checking oil whenya are done with the install....goood luck--a 2qm15 is perfect for your c30....i swears...btw--a perkins 4-108 weighs in at 600 pounds..yannies are a LOT lighter in weight----.
2,288
I will pass on the engine. There is a 2qm available right now. but I don't know how much an improvement it would be over the ysm12. Does any oone know if a 2qm will get it up to hull speed?
A 2qm has to be quiter than the ysm. With out the compartment coevers and cushions in place it sound like a tool box full of wrenches rolling down a hill.
Zeehag=do you have a 2qm on your ericson 35? If so what speed will it go and what does the boat weigh?
Hermit, just for comparison sake, the original Catalina 30s came with Atomic 4s (gas, HP was larger than the initial diesels which followed, but I forget exactly how much) - which were then replaced with 11 hp diesels, and then, over the eyars, built up from 11 to 21 to 23 to maybe 30 HP. Even the 11s moved the boat just fine. We have a 21 hp M-25 in our 1986 C34 and it works just fine for moving the boat. The history of C30 "powerplants" is most likely on their Association website. Good luck in your search. What's up with your SAILS & SAILING?
zeehag
Mar 26, 2009
3,198
my 2qm20h is a good engine--makes on my boat only 5 kts but i have wrong prop--with correct prop should be fine...2qm20h is an awesome engine---you would do very very well with any q2m engine-even a 2qm15-----awesome engines.......just make sure ye have the correct prop !! boat is 11,600 pounds.....
2,288
Last weekend I put the himod terminals on a new headstay. I took it down to the boat to put it on, but I did some epoxy work on the deck so it takes a day to dry. I didn't want my new static rope getting epoxy all over it.
Once I get the new stay on I can use the main sail only.
I never paid the fees for the association so I don't get on there.
