Hello SBO Members,
To describe Friday as "Good Friday" would be a misnomer in our case. Eileen and I spent a L O N G day at the boat removing the fuel tank. We had tried all arguments possible to avoid that project, but the bottom line was: the fuel tank is leaking. I had pumped the tank empty on Monday and had stored the smelly juice in containers on deck.
The decision to remove the tank was followed by trying to figure out just how to remove it. Initially all hose connections to the fuel tank were removed, and the holding tank with its associated tubing had to be moved. (It may even find a new resting place if we decide to reposition the fuel tank.) We cut the retaining plywood to the inboard side of the fuel tank for a distance of 28 1/2 inches. Thank heaven for the Fein Multimaster tool! With a combination of prying, lifting, pushing, and gouging out styrofoam we finally moved the tank. From that point the removal of the tank was pretty easy. It actually slid out over the engine once a few protruding parts were removed from the engine and engine area. That included the battery charger, the air cleaner, a drain hose, and just moving the shift cable.
The point of my post is this: aluminum fuel tanks corrode and eventually leak. That should come as no surprise to any of us, but when it happens be prepared to work your butt off. Our tank lasted 28 years. We had nearly convinced ourselves that someone (surely not us) had accidently drilled a hole in the tank while installing some errant screw in the area. Maybe we could locate the hole and patch it. JB weld was suggested by more than one person. Our investigation started by checking all fuel lines and then opening a small inspection area in the lower, forward corner of the fuel tank retaining plywood area. At that point we found saturated plywood and oozing fuel. A repair project became a replacement project.
Finding a replacement tank has proved difficult. The original aluminum tank is a 21 gallon tank that is triangular and its bottom is slanted both to the outboard side along the side of the hull and slanted aft along the shape of the hull. I am looking at Moeller tanks of various rectangular shapes and sizes to fit onto a shelf that I will install. It seems that I will be limited to a 12, 13, or 15 gallon tank in plastic. I do not have final dimentions because I have another day of cleanup before the soaked foam will be removed.
I have attached some pictures for your enjoyment. Our boat is a 1986 Caliber 28 that we have owned since August of 2013. We enjoy the boat's sailing characteristics and are excited about getting her back into the Chesapeake Bay again by mid May.
Notice: (1) There is no room to spare. (2) It's good I'm no heavier. (3) Pitting and discoloration on the tank.
Phil
Phil
