dry sailed in clinton
Hi Scott, My boat is 'dry sailed' at Spruce run over in clinton (I live in somerset county about 1/2 hour away). Except for years that the boat is travelling(florida a couple years ago; lake george this year)I rig it on the trailer once per season and break it down once. Nobody that uses Spruce run has been able to get a straight answer to the regular draining of water starting in early august despite our parking spaces being good till the end of october. I was out today and all docks have been removed and I had to launch/recover on the gravel in between launch ramps to keep from running up on the tire-stoppers at the end of the 'real'ramps. Same condition 2 years ago when the entire county was declared a disaster area due to torrential rains!
Back to reefing setup: My main is not a single line reefing but has padeye and cheek block at the stern end of the boom(didn't get a pic of it today)leading to a cleat midway on the boom. These boom end fittings are back several-maybe six-inches from the rear grommet. I still have to go forward to the front grommet padeye which is pretty much directly under the front grommet. When I fire up my home office computer I can post a few pics showing the wrinkle in the sail regardless of haylard tension. In fact as I was snapping the last pic I heard the thunder in the background and dropped the sail from it's reefed position and headed for the 'dock area' as fast as 4 HP could take me against the wind. Before I even got up to speed the errant sail slug had already slipped out of the flared gate above it(remember the sail isn't up). This makes me wonder if I need to sew another lower slug to stay in main channel.
I may yet consider a different place to sail from in the future. When I had my O'Day type 17, I would occasionally bring it to round valley(10 min from Spruce Run) where it was usually full but 'wide open' and nowhere to hide if it gets ugly as it has, indeed, earned it's "graveyard" nickname.Is there a lot of shallow water at hapatcong? Sorry for the long post...
