people capcity ratings
68
catalina catalina22 lake tillery NC
I have looked and looked and I can not find what the limit is as per persons and gear weight for my 1989 wing keel catalina22. I have seen this on every power boat I have owned or been on but on the 2 sailboats I have had there is no such plate. Can someone point me in the right direction? Alan
Timo42
Mar 26, 2007
1,042
Venture 22 Marina del Rey
When the water starts coming over
the rails, you may have it overloaded ;D Capacity plates are required for powerboats only, sailors are supposed to have more common sense than powerboaters and don't need the govornment to tell us when the boat is full. Tim
Dec 23, 2007
68
made me laugh
You made me laugh Tim thanks. So 12 people on my cat 22 is OK
jimg
Jun 5, 2004
175
catalina 27 dana point
Capacity ratings
The capacity rating (5 people or 800lbs, for example) is the load carrying capacity when the boat is capsized and/or full of water. Small boats, including small sailboats, dinghies, and relatively smaller powerboats have flotation built in and will float when capsized. When you get up to the motoryacht size, they are the same as keel-type sailboats. When they are full of water (with some rare exceptions) they sink.
Dec 23, 2007
68
up to five
Just so know one is confused I sail with no more than 5 people in my boat but mostly 3. I was just wondering why our sail boats don't have a rating. Alan
May 5, 2006
1,140
Knutson K-35 Yawl Bellingham
Oh Joy, according to the sailing calculator
sinks one inch per 900 Lbs. So, since she currently floats about 6" above her stock WL, this means I can put 5400#'s on her safely? Not on your life. Talk about a sailing slug.
Jul 5, 2007
196
Kenner Privateer 26 schooner, Carlyle Illinois
10%
I've always heard to keep the additional load( over normal crew and cargo) below 10% of the listed displacement in order to stay within design performance limits. So for a Cat 22; about 250 extra pounds?
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
For sailboats.....this is on the test
Number of people = vessel length (ft) X vessel width (ft) divided by 15
For example, for a vessel 18 feet long by 6 feet wide, the number of persons is 18 times 6 (or 108) divided by 15, which equals seven 150-lb. persons (or a total person weight of 7 x 150, or 1050 lbs.).
paulj
Jun 30, 2004
446
Hunter 340 St Andrews Bay
Sounds full to me
Paulj's formula says our 340 can take 26 person based on LOA or 20 persons based on LWL. Too much! Maybe ten if we all get along!
Dec 9, 2006
694
Oday 22 Hickory, NC
CharlieCobra...
I remember reading somewhere...and I don't remember where...it just stuck with me... that my Oday 22 sinks one inch for every 300 pounds. For what it's worth.
Jack
Joe
Jun 1, 2004
8,320
I've had ten on my Cat 27....
... and coast guard said okay as long as everyone had a PFD.
Sep 5, 2007
689
MacGregor 26X Rochester
The manual for my H340 says
it has a capacity of 10 persons + luggage = 1250kg. That's on page 35, which is the Builder's Certification Plate, with the CE mark. No plate on the boat, though.
Additional info listed:
Light Ship Disp. = 11,403lb
Full Load Disp. = 15,277lb
Sink @ Full Load Disp. = 3.76"
Interesting, but not sure how it relates to a C22. I'd bet if the OP called Catalina, they'd provide whatever info and certification data there is. But in the end, you still have to sail the thing, and what it will carry is probably more than you want while trying to control the boat, IMO.
Sep 6, 2007
324
Catalina 320 Gulfport, Fl
People often ask how many can sleep on my boat
These are people hinting they want to go with me. Except for really good friends, my answer is always the same. It sleeps 2, my wife and I. ;D
Aug 26, 2005
101
Oday 27 Corpus Christi
Manufacturer is best resource but...
the Coast Guard uses the formula that paulj gave for sailboats (and powerboats that were built before the capacity plate was required by law). Assuming a beam width of 8', your calculation would be 22*8/15=7.333 people.
Remember:
1) 1 USCG person weighs 150 lbs (and some of us are more like 1 and a half people because we are special). No honey, I'm not fat... this is ballast for the boat!
2) You are responsible for the safety of the people on your boat. If 7 people cannot fit safely on the boat, you are violating the law.
I'm not familiar with your boat but I would think 5 would be OK as long as you don't exceed 1100 lbs and can move around safely.
Capt Cook
paulj
Mar 16, 2007
1,361
Nick...........test
http://www.sailingusa.info/cal__capsize.htm
paulj
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
According to the formula . . .
I can put 7 people on my Capri 22 too . . .
Maybe when motoring. Sailing? I think not. Though I can see 5 or 6 if a couple are pre-teen kids and light winds.
