pendant c/b repair..
E
eric
i have an 83 oday25 i grounded a couple weeks ago my pendant i think is bust i cant feel the c/b's weight when i pull it. i am not sure if the pendant is all rope. i havent been able to find any info on the dimensions of the c/b. i think i will go under and repair it if i can however i dont know what it is i may need to do it right. what size shackle do i need if it needs to be replaced? is the pendant all rope? since i cant feel the c/b could it have broken off? this is my first sailboat so never mind my being daft about this. thanks
Jul 24, 2006
27
Oday 25 Anchorage, Alaska
pendant repair
I just did mine yesterday. I had to haul it because of water temp in alaska, but it would have been EASY under water. I have a 76 which I understand is a little different that the newer boats but I changed mine to work more like yours with a shackel. Some of the boats had a cable attatched to a rope but everyone says to jettison the cable and run rope down all the way to the CB. I used 1/4" line. The clearance inside the keel is fairly narrow so after buying several different shackles for the job I found that the U shaped shackles seem to be the best fit (as opposed the the horseshoe style). The CB is shaped like a wing with the aftmost edge tapering down to about 1/8" and flaring out, rather quickly, toward the center to about 1" thick. My shackle which worked pretty good had...a 1/4" shaft, was 2" from top of the U shape to the shaft, and was 3/4" wide measuring the inside diameter. Also chose the shackle with a cotter pin locking mechanism instead of a screw in type. Oh yeah, grab a good 18 foot of line, too much is better than not enough. It's easy to cut and cap when your done. Good luck, you will find this to be a fairly simple job.
Oct 16, 2005
3
Oday 25 nyc
83 oday25
thanks for the info i reckon i will dive and do it myself i just really wnated to hear that it can be done thanks again
