Pelican Hook specs for 1999 Hunter 280
Miken
Nov 7, 2018
13
Hunter 280 Whitby
I need a replacement for my pelican hook on my 1999 Hunter 280 (nothing in manual or Internet). Looking for-threads per inch, right hand or left hand threads, and any other specs I need for an order. If someone could respond with a make and model it would be great.
Cheers
Mike
Mike, where does it attach on your boat. If the lifeline there is a reference in the SBO Shop to a hook that fits the 280.
Johnb
Hunter 37-cutter Richmond CA
Measure the outside diameter of the male thread.
Determine wether left or right by turning the locking nut.
You then have it. Note that it could be different from original on a 25 year old boat. Be prepared for sticker shock.
  • Helpful
Likes: ggrizzard
Miken
Nov 7, 2018
13
Hunter 280 Whitby
Sailing today so I took some measurements.
Overall length-5”
Thread size-1/4 “
Left hand thread
Does this sound correct, and if so can somebody recommend where to get one?
mike
Did you check out the link to the SBO Shop, I posted. Here it is again. They show the Hunter Pelican hook for the life line.
Miken
Nov 7, 2018
13
Hunter 280 Whitby
I did but they wanted $32 to ship to me in Canada. I may have found one at the Rigging Shop in Toronto. Thanks for the help
2,151
Are your lifelines at or near the 20 year mark? Replace them, and use the newer C.S. Johnson Over Center Snap Gate Pelican Hook, as they are much safer. BTW, Most riggers will pass thru their lower price for these and other parts when they build the new lifelines, so the price will be more reasonable than you might think
