Peeling clear coat
Sep 27, 2013
1
Hunter 31 Rose Haven MD
I am relatively new boat owner. Last year was first year with 1984 Hunter31. Long story short - Her fiberglass deck is shedding. Discussed with previous owner, and he applied a clear coat to deck a year before I purchased her. The clear coat has turned yellow and that is what's peeling. I need to find best way to remove the existing clear coat, and then do whatever is required to obtain shine. In cleaning the interior, I noticed mineral spirits and a razor window scraper removes gunk residue without any damage. This would take forever to do same to deck. Some does peel readily from razor blade but not all. In using penetrol as paint additive unrelated to this, I noted can says it can be used to clean fiberglass by applying, letting set for 3-5 minutes, then wiping off. Before I attempted that I thought it best to seek advice. I don't care how much effort it takes to do whatever is required, I just want to make sure the job gets done right, with no damage to her.
Dec 28, 2009
397
Macgregor M25 trailer
Most of the clear coats are acrylic based, a strong solution of ammonia and water will probally cut it, or try a floor wax stripper.
Dec 2, 1999
15,184
Try using ammonia and soapy water to see if that removes it. The more ammonia the better. There are removers from the different mfg of the acrylic coatings. Not a lot different from the good ol' floor wax.
MSter
Apr 12, 2010
131
Sabre 38' MK II Oriental, NC
If you have automobile clear coat you will need a special paint stripper suitable. It would be very important to check compatability with the fiberglass deck first. Mike
Oct 17, 2011
2,809
Ericson 29 Southport..
Knowing what this 'clear coat' consist of will be a great help. Lotta difference between stripping floor wax and removing clear paint..
