Beverly SV "Sight Unseen"
I am having a problem with the bottom paint peeling off in large chunks. I was told that this boat was not properly preped when it was originaly comissioned. It is a 1999 Hunter 380 and I am the 3rd owner. The boat started out in Florida, went to Lake Ontario and then down to the Chesapeake in a course of 3 years. I have had the boat out of the water 2 winters and noticed the paint problem 2 winters ago. I was told to sand and feather the edges and it wouold be OK. Not so. I used a Petit Trinidad paint because the boat was going to spend the winter in the Bahamas. When the boat was pulled in the fall of 2004 I noticed the paint peeling off in big sheets. Now that it is Spring, it needs to be addressed. I was told that the whole bottom has to be sand blasted and repreped as well barrier coated. I would like additional information on this issue. Is it possible that this hull was not properly cleaned before the initial painting in 1999? Is there any other way to fix this problem? The hull stripping and repainting will cost over $4,000! Thank you for any help anyone may offer. CapemayB@msn.com
