Pedistal Feet
I installed an Edson pedistal guard on my '90 H30 a few years ago. You need the feet to properly install the guard. If you order the whole thing from Edson, the feet come with it, but you can purchase the feet separately if you are going to fabricate your own guard---just make sure the tube diameter is the same.I drilled completely through the cockpit sole. There were aluminum plates in the sole, similar to the cabin top for winch mounting. I could have drilled and tapped, and used machine screws, but decided to drill clear through and use very large (3 inch) washers and bolts, thinking it would be stronger. They take a lot of abuse....
