Pedestal mounted throttle & transmission controls
Sep 29, 2015
97
Catalina 30 2188 St. Petersburg
I have a 1981 C-30 with Universal 5411. I would like to move my throttle controls from the port cockpit bulkhead to the pedestal. However I am reading that because the transmission is reversed on the 5411 we can not use the pedestal mount. Does anyone have experience with type of setup on a 5411?
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
5411 with pedestal mount. It was pretty much standard in 1986.
Sep 29, 2015
97
Excellent! Do you remember what size cable you used? Did you turn your transmission shift 180 degrees in order to have the controls correct?
Jul 14, 2015
840
No idea. Boat came that way from factory.
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
(looking at similar issues on my boat) The "standard" engine controls (as shown in the pic) makes the cable PULL for fwd, PUSH for reverse.
You have three options:
1. Rotate the shift lever on the transmission and make a custom bracket so pulling the cable will shift into fwd.
2. Get the "reversed" engine controls from Edson - it has the shift lever kinda sideways, and it makes the cable PUSH for fwd.
3. Just hook it up and live with the fact that your shift control is backwards (ie you pull the lever BACK for fwd, push it FORWARD for reverse)
I did #3 on one boat: it works but it's confusing and may lead to disaster when you shift into fwd when you mean to shift into reverse. Picture Will Smith starting out flying the Flying Saucer in Independence Day...
I'm doing #1 on my boat.
druid
