Pedestal Guard
Jake Barnes
I have read all the archives on the pedestal guard for the Hunter 31. When I called Edson...they say that I have to drill and mount the bottom of the guard to the deck. I thought most people said that it would leak and they have a special mount so I don't have to do that. Any ideas? Thanks.
bob G.
Watkins Glen
On my 85 H-31 the pedistal guard receiver is bolted into the floor, a factory intall I assume. When I saw the location it brought back great memories of going to the race track for the formula one races back int the seventies. Seneca is a beautiful lake (grew up in Binghamton)
Feb 27, 2004
134
Hunter 410 N. Weymouth, MA
edson pedistal guard
Jake, I've had the Edson pedestal guard on my H410 for 6 years. so far no problems. it's a pretty simple install. had to cut a hole in the headliner of the stateroom and I covered those with a small piece of teak. Bryce
Aug 13, 2005
23
Hunter 31_83-87 Ventura, CA
No leak
On my 84, the mounts for the guard are throug bolted into the back bunk area.Have had no trouble with leaks. Use a good sealent and you'll be fine. Dennis
Dec 25, 2000
5,945
Hi Jake, it depends upon the type of mount...
The straight Edson mount that I installed on our H28 was secured to the cockpit sole. I used screws (through bolts are better) and 3M4200 sealant; it did not leak and was very strong. The off set Edson mount on our current boat is attached to the pedestal. It is also very strong and did not require any holes in the sole. Terry
Jake Barnes
Thank you
Thank you all for the input. As always...putting another hole in the boat is something I try to avoid. Thanks again.
