I'm still trying to make helm improvements and have mostly frustration so far, and more questions than answers.
I'm changing out pods mounted on the original offset guard and I ordered a new "offset" guard kit from Edson. They sent me an "angled" guard by mistake. I confirmed it was a mistake because the packing slip even calls it "offset".
But now it's got me wondering .... maybe I'll like the angled guard more! The only difference, aside from the angle vs offset, is the top of the angled guard is a little bit closer to the aft end than the offset guard (as approximated above). I'm not sure that I'll like the viewing angle of the chartplotter pod better or not. It will give me more flexibility in the height that I position it, I think. The lower pod in the photo is new and it houses a 12" B&G chartplotter and 2 instruments. I plan on replacing the upper pod, that currently houses 3 RM instruments (speed, wind, depth). The chartplotter pod will house the CP, autopilot control and I thought just one B&G Triton instrument (I have 2 new ones). I could completely eliminate the upper pod. I'm thinking about keeping the angled guard they sent me .... any thoughts?
But I'm still struggling with the engine instrument pod. I made a new trim ring for the existing panel, but I can't seem to slide the instruments any deeper into the pod (to provide the space I wanted) and the tachometer is the problem because it is the deepest instrument in the pod.
Now, I'm thinking I can make an entirely new face panel and rearrange the instruments so they fit in the pod. I'll take the tachometer out and I can mount it next to the chartplotter! That's the only instrument I really want in view anyway. I figure, the wiring to the tach in a new location shouldn't be too difficult to handle. That pod would then have the CP, the pilot control and the tach. I'll mount either one or two Triton displays independently.
The tachometer is a magnetic pick-up at the sender, right? Is there any reason why the tachometer instrument should cause any interference in the chartplotter as I'm motoring along, if the instrument is right next to the chartplotter in that CP pod? I think the CP pod is deep enough ... I'll have to verify that small detail as I didn't think of it yesterday.
Below is the yanmar panel that I would replace with a customized version minus the tach. It goes in the pod underneath the wheel.
