Bejasus
I have a friend with a Pearson lying in Savannah and he has a problem with his boom furling mechanism. It is the type with a wire 'topping lift' attached to a rotating bolt on the end and a cast aluminum cranking end at the gooseneck that takes a square crank handle. The problem is that the round part of the mechanism, that the boom fits into, has split and the mechanism needs to be replaced. However, I have searched for this product without success. Can someone point me in the right direction?
