Pearson 530 strut attachment
capta
Jun 4, 2009
5,074
I have been searching for any interior nuts or threaded plate that the strut on our Pearson may have and been unable to find anything at all in the aft section of the boat.
Does anyone have any idea of how Pearson secures the struts to their boats? If I remember right, there are 6 or 8 screw/bolt heads on the strut outside the boat. I can't imagine that the strut is lag bolted on?
Thanks.
Aug 2, 2005
1,155
Hello capta,
If you are talking about a shaft strut that would house a shaft bearing I might have some information you can use. We have owned several O'day sailboats, and since the companies were "related" this might help.
On our 1979 Oday 30 the shaft strut was attached using 4 large machine screws that threaded into nuts that were epoxied within the hull. There was nothing visible from inside the hull. On your larger boat there may be a plate within the hull instead of the individual nuts that were in our Oday. As often happens 3 came out with some grunting and turning on a large Phillips head screwdriver. Number 4 was less cooperative. That nut turned within the fiberglas of the hull and had to be "surgically removed".
All the work was done from under (outside) the hull in order to remove the strut and the cuttless bearing which had to be cut in thirds to tap out the long pieces. (But I digress!)
To replace the nut that had turned in its location I used a thickened epoxy to rebed a new nut in place. Positioning the nut properly was done using the holes in the strut as a guide and putting the three originals in first. Keeping the epoxy out of the threads of the nut was accomplished by packing plastic wrap into the threads. I think I used six-10 epoxy because of its thick consistency. Replacing the machine screw went OK, although it didn't just slip right back into place.
I hope this is helpful, Phil
capta
Jun 4, 2009
5,074
Hello capta,
Well, I'll find out in a couple of days. It sounds about right, though, because I can find nothing inside the hull.
Thank you.
NYSail
Jan 6, 2006
3,181
Beneteau 423 Mt. Sinai, NY
In 1981 oday and Pearson were not related. My 86 Pearson has nits and a backing plate inside hull above the strut and under the exhaust water lift. My friends 1980 also has same. You may want to call Rudy at d & r as he worked for Pearson for many years and may know how they were attached. Would shine for as much torque your engine puts out they would want to attach very securely...... Good luck.
capta
Jun 4, 2009
5,074
Still no info on how Pearson attaches the strut on the 530. Any info or suggestions welcome.
Thanks.
