pearson 34 stanchion
NYSail
Jan 6, 2006
3,155
Beneteau 423 Mt. Sinai, NY
I bought all new from Garhauer for my P36-2. Got the base with removable tubes and love them. However if you are in need of the originals, I may be able to help as I have not thrown away the old. Snap a couple of photos of your stachions (base close-up etc) and I will see if they are a match
Oct 17, 2007
40
- - Washington, DC
We did the same - two of ours were damaged in a storm last year and I found the cost of replacing those with the originals was more than the cost of upgrading the whole boat. I called Garhauer and they emailed me the dimensions of several of their stanchion bases, and I picked one that was large enough to cover the old Pearson mounting holes. They don't line up, so I filled the old holes with thickened epoxy and drilled new ones. The new stanchions are much more robust than the old ones. Garhauer also supplied stainless backing plates. The only source was able to find for the originals was Rigrite. Again, they were very expensive. Our boat is an 84 P303, so your stanchions may be different.
