This is a question for Pearson 303 owners. I am replacing my thru hull depth sounder transducer. Here's the question there is an access panel in the v berth soul were the transducer is located however my transducer is located about 2" under the v berth soul. I could not remove it or service it without cutting the floor or cutting the transducer. I think whoever installed the transducer drilled the hole in the wrong place it needed to be drilled 3" further back. how about you other Pearson 303 owners is you transducer directly under the access panel?
