Thanks for the reply. I thought it should be 1/4" not 3/16" packing gland material. I previouly owned a Pearson 28-2 which had the same size 1" shaft and I used 1/4" packing which had minimum to no leaks. I am surprised the bilge does leak in water since the only drain to the bilge is the ice box. I have a project to find the other sources of incoming water. My thought is their should be none.
Jerry (hull #314)
