Just curious if anyone has made any modifications for Jib furling that would make it easier to reef the Jib? My boat has what I believe to be the original setup from the factory as there is a cleat attached midway up the stanchion where the line is tied off there is also a cleat just across it on the side of the cockpit coaming that can be used to tie off the line as well although in heavy winds I would be reluctant to use it. Has anyone added a block or cam cleat to lock the furling line in place? Since the boat is a mast head rig even the stock 110 jib has a pretty large surface area.
