Can someone point me in the direction of instructions on how to use the Passage 42 in-mast furling system? (Z-SPARS)
We are considering purchase of one and while on sea-trial the sail became completely jammed in the mast. (Likely the result of a bad furling job by the previous user) We got it back to the dock and, with a rigger up the mast, we were able to get it out, an inch at a time. It took almost 2 hours because it was seriously jammed up in there.
Once it was out, every time we tried to unfurl it, the furling line would double-over on the spindle causing it to jam. What's the proper technique for preventing this so the line lays neatly in a single layer?
Also, it seems important to have the boom-vang and topping lift set correctly for a good furl/unfurl. Are there any guidelines for this?
Any common modifications to make this easier to use? This boat had it's running rigging replaced and it seems like the lines are all in different places than when original from Hunter. I'm just trying to figure out if it would make sense to put them back where they were originally or if there was some reason they rearranged everything.
Thank you!
Thank you!
