E
Ed Sabornie
Dear Peggy,Here's a question that I hope you can answer, and I hope my description below is adequate enough for you to comprehend. If you have a hose (specifically, the 1.5 in. sanitation hose from the holding tank to the deck pumpout plate) that is permeated, is it possible to replace a part of it and splice/replace with the Odorsafe hose without replacing the entire hose? Here's my dilemma: The bottom 1/3 of the hose from the tank to the deck pumpout plate holds waste because of the way it is attached to my holding tank. To get to the top of that hose where it attaches to the deck pumpout plate is going to be VERY, VERY difficult because of space constraints on my '97 Hunter 280 (and the boat dealer said it would take 1 day alone to replace that hose!!!). Splicing that hose above where the waste collects, however, would not be hard to do. What I would then do is use the proper barbed hose connector with clamps and have the Odorsafe hose on the bottom 1/3 and allow the Odorsafe hose to collect the waste. I guess my real question is if the entire hose needs to be replaced when it is permeated, or can you just replace part of it that constantly has waste accumulating in it? Would doing so (splicing) in the manner I described above be as effective as replacing the entire hose? It sure would make my job easier if I could replace only part of the hose rather than the whole thing, but I want to eliminate that nasty smell.Many thanks for your expert insight on this matter--you're the best!
