So, I've finally got my plan. I'm going to use 2 Lifeline group 31's (GPL-31T) in parallel for a house bank and a Lifeline GPL-1400T for a dedicated starting battery. The small size of the 1400 will allow me to get all 3 batteries in the space that's sort of reserved for batteries in my Cal 28-2, under the port settee in the cabin. This will give me a 200 AH house bank and a very adequate starting battery for my little Westerbeke W13A. With my BlueSea "on-off-combine" 2 pole battery switch, this allows dedicated house and starting banks which can be combined if needed.I've read Nigel Calder's "Boatowner's Mechanical and Electrical Manual" and Charlie Wing's "Boatowners Illustrated Electrical Handbook" as well as perusing many different forums, and I still can't find the answers to a couple of questions. 1) Should the paralleling cable between the 2 house battery positives be fused? If so, how big should the fuse be? 2) Where does the fuse go? The ABYC apparently says the fuses should not be in the battery compartment, but this cable never leaves the compartment. 3) For that matter, what wire size should the paralleling wires be? I'm assuming the ABYC has spec'd all this, but I can't find this information anywhere. The ABYC wants $130.00 (non-member price) for a downloadable copy of the spec.
