painting the deck
P
Peter
I own a Catalina 22 built in '77. The deck is beginning to wear badly, and I find lots of powdery gelcoat as I wash it. Should I consider painting the deck with a top-end polyurethane paint, or must the existing surface be replaced with gelcoat? Thanks for any help.
Ted
POLI-GLOW ;D ;D ;D
depending on how bad things are, you could probably get very good results with a "co-polymer" restoring product, namely Poli-Glow. www.poliglowproducts.com It is not a wax, and it lasts for several years without any maintenance. I used it on my boat 4 years ago, and it was amazing. This would be a far better approach that painting, as paint will eventually peel. Check out my web page for some pictures of the restoration project using PoliGlow(link below). Regards, Ted
Jess
Poli Glow on nonskid
Ted, Thanks for the info on Poli Glow. I used it on my boat with equally good results, but I avoided the nonskid to avoid making it slippery. With one coat on yours, did you find it slippery. Regards, Jess Precision 18
Ted
Yes . . . it was slippery
. . . but I managed to stay onboard. The pop-top was particularly slippery, even with one coat of Poli-Glow. The deck surfaces were not too bad. I will probably avoid the non-skid areas at the next re-coat. Regards, Ted
tom b. catalina 22
um.. ur talkin painting the deck around the non
skid right?? mine is a 70 something and the white had worn off in some places leaving me with yellow spots(not really spots),ok, areas..well i havent had the boat in the ocean yet, but,,,,sittin in my backyard, i repainted the topside with spray paint from the hardware store..(yea, i know) i found some paint that is used to paint appliances with. so far after a year in the backyard without being covered...it still looks great. the paint is very glossy and seems to like a waxing every once in awhile.(note:be sure to use paper and masking tape to things u dont want painted....)hopefully we'll get her out soon. just need to get the trailer ready to go now. and im off..sailing that is..
