Painting CB and Rudder
Sharon
Another newbie question. Need to re-glass the leading edge of the CB and bottom of rudder. Not being certain what they are both made of, I picked up West System 105 Epoxy Resin with 205 Hardener along with glass tape (for the CB) and 406 Adhesive filler. Sound right? Thanks in advance, Sharon
L
Larry
Epoxy
You got it right, just follow label directios carefully and you should be fine. Mix small batches rather than one large one. I would apply two or three coats(after each epoxy batch dries) rather than one thick coat. Sand withh 100 grit before painting...cheers
