paint...
Member 131497
gentlemen, once again to inquire answers from this vast huge vault you're.... tbx in advance
so, what to paint topsides first, non skid or the rest of it?
C
Oct 24, 2010
2,405
Hunter 30 Everett, WA
More questions: what surfaces? Fiberglass, wood, metal, high wear areas or just cosmetic, exposed to weather or interior?
Likes: Member 131497
Member 131497
the prep was done on all of it(deck) things were removed, sanding done next is EZ deck. BUT... what to do first? non-skid areas or the smooth areas?
Nov 30, 2020
79
Macgregor 22 Dania, FL
I think it may depend on how much of each surface you have. After priming, I painted non-skid first because I have so much of it. Then I came back and did the small area of shiny white. I went from biggest area to smallest area and it worked okay.
Apr 8, 2010
2,235
We are in the final stages of a re-fit. The plan is to spray the hull next, primer, color coats, and then clear coats.
Next the deck gets shot, same regimen. Primer coats are done on the deck at this point. Before that, almost 150 holes were over drilled and epoxy filled and re-drilled. It's been satisfying, and quite a different way to spend time alone during a pandemic. :(
Next, reinstall all of the deck hardware, and then design out the non skid boundaries around the hardware and shoot the non skid.
Likes: SailingLoto
Reading your post, I am assuming you are painting the Deck not the "Topside - the area from the waterline to the rail around the boat's hull".
You have two choices. Paint everything the deck color ie. white. When this has dried go back and tape off the areas to be non skid and add a second layer of paint (color of your choice), then sprinkle the non-skid material into the fresh paint.
Or you can try it in reverse - which assumes in your prep there is a good base to paint on and that the base film is such that there will not be a break in the paint film.
I choose plan 1. I like the idea laying a solid paint film coat down to color and protect the deck. Then coming back with the nonskid coat over the top within the taped sections. There should be a normal transition from base coat to nonskid and the transition will not be noticed.
Good luck.
Joe
Jun 1, 2004
8,310
C
Non skid last. Why? Taping on non skid to paint smooth areas is near impossible. Have you considered Kiwi-Grip for non skid?
Likes: RoyS
Dec 27, 2012
587
Precision Precision 28 St Augustine
I agree with Joe with both the order of painting and use of Kiwi grip.
PaulK
Dec 1, 2009
1,522
Sabre 402 Southport, CT
What you paint first depends upon your technique. If you do the smooth sections first, you have to mask them off when you do the nonskid, and the masking tape may lift the new paint when you pull it off. Oops. That approach also makes two separate areas of paint - no overarching, complete coverage of the whole deck in one film. If you do the nonskid first and then paint over that with smooth topcoats over the whole deck, you get the whole deck covered in one film and you don't have to mask the nonskid areas when you do it. It's less work.
EZ deck? If you don't want to do it all over again next season, you might want to be using a 2-part polyurethane paint. When our first 2-part poly coats on our deck started to wear out about 12 years after we painted it, we tried Interdeck (Interlux's version of EZ-deck), hoping it would be easier to apply, and cheaper. It did not hold up well. Since the prep work for both types of paint is similar, having to re-do the cheaper paint doesn't end up being cheaper because it has to be re-done. We spent this spring repainting our deck with Awlgrip, which we expect to last about 12 years. EZ deck may hold up better than Interdeck, but be aware. Forewarned is forearmed.
