Sorry Bill - also on paint removal etc.
We have new phone numbers 1-877-434-2089 (spillover order line) 1-510-868 0208 and new fax number: 510-868 0817, E-mail address is now islandgirlproducts@mac.com.Unfortunately autoresponder and newsletter stuff is still giving old data. We did get together on 1-800-441-4425 that has been kept as our only landline.With regards to pain removal from gelcoat:1. You cannot use regular paint remover - it will strip the gelcoat.2. Oven cleaner is very caustic and contains a little glycol ether. Caustsic accelerates the paint removal properties of glycol ethers. Be careful, use gloves and well rinse with water. There are some reports of yellowing of gelcoat after using oven cleaner.3. If you have ANY IG cleanser, it can be used to remove painted lettering without damage to gelcoat, hypalon, rubber or vinyl. However, IG Pink is more gentle (use white scuff pad) and works faster in warm weather. 4. ONLY IG Pink can be used to remove paint or marker grafitti resins, sealants, tar (if you are short of mayonnaise!) without damage to underlying plastics (except cellophane or crazed acrylic). You can even use it safely on automobile or house paint.Hope this is of some the movie link shows all this with specific instructions given in a droning voice (mine!).
