For fine finish painting on topsides and interiors
temperature can make a big difference. Paint just won't flow right if it's too cold, and it can take a long time to dry, so dust and bugs have more time to creep in.Bottom paint is not as critical, unless you're one of those serious racers that wants a glass smooth finish on the bottom. Like Rick in Toronto, we bottom paint here in BC if it's not below freezing or raining so hard it will wash the paint off. That's for conventional paint.If it's a two part epoxy or some other new and different product, the folks who make it usually have tech support through a contact number on their website.One part "epoxy" bottom paint is pretty much like a high quality oil base paint.I wouldn't use it in really cold weather, but over 40 F. should be OK.You do need to use paint that's compatible with what's there already, get all the loose stuff off, then make it as smooth as you want.
