Paddlewheel suggestions?
Sutric
Jun 24, 2021
41
Seafarer 26 Carlyle IL
Hey, Does anybody have any suggestions for keeping the boatspeed paddlewheel spinning? I clean mine and it works fine for about three weeks then it builds up an algae layer and stops spinning. If there is a magic treatment or something that would keep it clean, I would really love to hear about it! Thanks.
May 1, 2011
5,019
Pearson 37 Lusby MD
Remove the paddlewheel and install a blanking plug when the boat is not in use.
BarryL
May 21, 2004
1,068
Hi,
The only magic I know is to either use GPS speed or an ultrasonic transducer.
I paint my paddlewheel (the sensor is an Airmar DST800) with antifouling paint. Even so I need to pull the paddlewheel and clean it, or dive under the boat and spin it by hand a few times before it starts to work.
Good luck,
Barry
No magic. There are some really expensive anti-fouling paints that might work. Otherwise, it is pull and clean or pull and plug after each sail.
Likes: Rich Stidger
Feb 10, 2004
4,137
Hunter 40.5 Warwick, RI
I pull and plug after each sailing period. If I am using the boat for several days or weeks, I pull it and spin/clean when I notice it not working. I can easily pull and clean from inside the boat without a major flood, so that makes it easy.
Likes: Ward H
I used to keep a toothbrush and scraper in the compartment where the thru hull was on my H356. Also a sponge. I'd advise to not wait until the paddlewheel stops turning to clean it. It should be like any scheduled maintenance. Even if it hasn't stopped it has more resistance and therefore less accuracy as it fails.
I used the blank if I was away from the boat for ...? Certainly I would leave the paddlewheel in for a weekend on the boat or a cruise. A normal week, with a Wed PM race I would probably leave it in - but clean it. I would clean it when doing the bottom, which could be as often as once every two weeks or before a weekend race.
In the area we sailed there is a good deal of current. Watching the difference between boat speed thru water vs. boat speed over bottom was a racing tactic to either take advantage of current, or mitigate adverse current. It was important to myself and to my competitors.
Oct 2, 2012
14
Fountain Pajot Bahia 46 128 Abroad
Hey, I have used dioelectric grease in the paddle wheel and case area for over 20 years with good success. Lasts about a month or two.
Likes: Daddio417
JVB
Jan 26, 2006
270
Schock Wavelength 24 Lake Murray, SC
Copper ! Cover the paddlewheel with copper when the boat is docked. Closer fitting, like a cap, would be better but just a plate adjacent or suspended below the paddlewheel might work in still water.
Aug 11, 2011
980
O'day 30 313 Georgetown MD
I sail mainly in the Chesapeake Bay. I use my Garmin GPS for my speed over ground. When that isn't working, my guess is that I've just run aground. Calling Tow Boat US "Hi there, this is embarrassing but could you........." :p:laugh::clap:;):biggrin:
Oct 29, 2012
353
Catalina 30 TRBS MkII Milwaukee
Try taking the boat out sailing more
Sutric
Jun 24, 2021
41
I normally use my depth sounder to confirm when I'm aground. So far, it's been right every time!
Sutric
Jun 24, 2021
41
Thanks for all the suggestions! I'm going to try the transductor paint and see how that goes for the first effort.
