I use the transducer paint
@Rich Stidger mentioned. It is a small bottle but it lasts many years. I’m not in a high fouling area but with the transducer paint I easily get to late summer before there’s any inaccuracy from fouling.
Not to say that the transducer is 100% accurate anyway - mine is mounted alongside the leading edge of the keel, so it is heavily affected by water flow over the foil. It reads much higher on starboard tack than port. I’ve learned to compensate for that mentally. I rely on GPS speed for most things but I still like having the paddle wheel to see the effect of current.
My B&G and Simrad instruments can be set to use SOG or STW for the true wind calculation. The problem with using the SOG setting for the wind calculation is that for some reason that makes all of my instruments show SOG on the Speed Through Water read-outs, which is annoying. This winter I added a Raspberry Pi to my NMEA network that can do the Ground Wind Speed calculations itself and not interfere with the display of Speed Through Water.
