paddle wheel sensor, LEAK
Apex
Jun 19, 2013
1,222
C&C 30 Elk Rapids
looks like the bedding compound is crumbled away allowing for a small leak, maybe 1/2tsp per hour? this does not have a inserted wheel section, it is all or nothing.
wait for fall since it is so little?, spray some flex seal from inside?, go for a swim and stick some chewing gum, duct tape and putty?, or emergency haulout and replace?
interested in opinions (regarding the repair)
Oct 29, 2005
2,366
There are 2-parts putty that works underwater. Try that if water not cold. You'll never know when it gets worst.
KenY
Likes: Apex
There might be a fix with the underwater epoxies or some caulk that can cure underwater, like a polysulfide.
If going down the temporary repair, remember it will be necessary to remove whatever you put there in order to make a permanent repair.
Likes: Apex
