Pactor...more
Thanks John, I agree, there is much to learn here from everybody. OK Richard, I started with a novice license back then, then the tech, then gen, then Extra. We are in La Paz on the Sea of Cortez and use the Baja ham MM nets for our cruising grounds (Chubasco net, 7294 MHz, 8 AM, for example). We use HF SSB when out at sea to stay in touch with other cruisers, sometimes a phone patch back home (CA). We use a TS 50 at 50 watts usually. Sometimes listen to MM nets (get the ARRL book of nets). With Pactor, we have found early AM to be the best for traffic. There are popular gateways, we use others. See Winlink.org and the list of stations. I usually connect to Texas, CA, or even the east coast. The software comes (free download) with a propagation program that indicates which station is best at a given time. There are lots of stations to connect to, each station then scans several bands/freqs. Some as many as 10. So you have plenty of opportunity. In the marina can be a pain due to some using too high power, but 10 watts usually works (some use 150 all the time). Static a problem? This SCS unit is so sophisticated, it can detect the digital signal when I cannot even hear it...just prints away on the laptop. Take a look at the software by downloading it (and propagation pgm) from Winlink and play with it. You don't need the controller to check it out, especially the prop pgm. Being in La Paz used to mean being isolated, but with daily e-mail (several times a day) it isn't any more. Installation is not a problem, I connected everything at home, made it work, learned much, then took it to the boat.Hope this helps. Jack Swords WA6WTH
