Packing hose vs exhaust hose
Sep 24, 2018
4,001
Catalina 30 MKIII Chicago
Whats the difference in construction between packing shaft hose and exhaust hose? Has anyone torn both apart to analyze the internal construction?
Oct 6, 2007
1,164
Hunter H30 1982 Chicago IL
Shaft log hose is much thicker than exhaust hose and has multiple layers of reinforcement. It’s so thick and sturdy that it actually takes several days to completely tighten the hose clamps.
I think the reason for this may be that shaft log hose is subjected to engine vibration, lateral movement in relation to the hose, at one end and no movement at the shaft log end which is less than a foot away. This kind of differential movement puts sheer stresses on a short length of hose that will quickly cause thinner exhaust hose to delaminate and fail. It’s also a hose that is more difficult to change, requiring that either the engine or the shaft be pulled. It’s not a quick, easy fix if it fails.
It’s tempting to substitute cheaper exhaust hose, and many do, but it’s not the right use of that kind of hose. Shaft log hose is designed for this purpose.
Shaft log hose is designed to resist the constant torquing that occurs on the packing gland. Unlike other hoses and fittings that go below the waterline you can't shove a bung into it if starts to fail. A failing shaft log hose is a catastrophic failure, you best hope someone is nearby to pluck you out of the water.
Likes: Dalliance
Oct 6, 2007
1,164
Thanks. Torquing is a better description than lateral movement. Sheer is the result of both.
dmax
Jul 29, 2018
1,258
Telstar 28 Buzzards Bay
It's also very stiff and wants to stay straight, which helps when trying to get things aligned.
4,001
I'm also seeing heavy duty shaft log hose. Is this really necessary on a 23hp motor? On a 150+ it makes sense but I'm skeptical for a sailboat. Surely doesnt hurt
send us a couple of links to what you are looking at.
Oct 6, 2007
1,164
The brand I’ve used for both shaft and rudder logs is Buck Algonquin.
Oct 6, 2007
1,164
How is shaft log hose different in that respect from any other hose?
Because the prop shaft passes through it. Have to pull either the engine or the shaft, or at least uncouple the shaft and slide it down if you have the space, in order to replace the hose, regardless of hose type.
Nov 22, 2011
1,277
Ericson 26-2 San Pedro, CA
Yes, regardless of type. That's what had me confused with your comment. I thought you were suggesting that replacing real stuffing box hose was somehow different in that respect.
Oct 6, 2007
1,164
Got it. Only difference with actual shaft log hose is what I mentioned about it taking a couple days to completely tighten down the hose clamps because the hose is so thick.
Sep 24, 2018
4,001
Buck Algonquin makes a log hose but it doesn't say heavy duty. It's surprisingly difficult to find in 1-5/8".
CD's regular hose. I think they're trying to pass off exhaust hose as log hose.
Stuffing Box Hose Kitw/ Clamps 1-5/8" I.D.
CD's heavy duty hose
Stuffing Box HD Hose Kitw/ Clamps 1-5/8" I.D.
I'm looking at BA as well as Catalina Direct's heavy duty kit. Price for one installation ends up being the same even though you'll get 12" with BA
Overtighten your packing on an engine with a vibration problem and then see how you feel about it :yikes: !
I got me a brand new coupler, shaft and cutlass! We suspect the yard lifted the boat by the shaft prior to me buying it. There was visible wobble
Nov 22, 2011
1,277
Right. I’ve changed it out before. Really thick stuff. I need to do it on my current boat as well.
Likes: Dalliance
Oct 6, 2007
1,164
I’ld be curious who manufactures the hose that CD is selling. I’m sure it’s good quality. If they‘re selling it in the length you need and including good quality hose clamps, it looks like a good deal. I don’t recall what I paid for BA hose and four solid ABA hose clamps, but I‘ld bet it was more. I had to buy a 12” length of BA hose and cut it down to five or six inches with my utility knife. I may not recall the price, but I do remember blisters on my hand from cutting that thick hose. A utility knife may not have been the best tool choice. If you can get it precut to the length you need, it will save you some time and toil.
7,443
I always swear by a brand new 32 TPI hack saw blade for getting through sewage and exhaust hoses.
Haven't had the pleasure of cutting a log hose yet and from what I've seen here, not looking forward to it either.
Likes: Dalliance
Sep 24, 2018
4,001
I think the next time I have to cut a heavy hose, I'll lube the blade with some dish soap. It's always the friction on the side of the blade that makes it difficult
Likes: JoeWhite
Jan 7, 2011
5,862
Oday 322 East Chicago, IN
@Project_Mayhem,
Dave,
Ou are putting a lot of money into your new boat and upgrading things as you go…this might be a good time to consider switching to a dripless seal of some sort.
i like the Volvo Penta dripless rubber seal, for its low cost and simplicity. But as we discussed, I do “burp” it every time I open the engine intake because it is right there in the engine bilge. If that is not convenient on your boat, you could consider a design that has an air line on it for purging air out of the seal. The PYI version allows for that.
Greg
  • Helpful
