h34 Stuffing box
It's a great old piece of bronze hardware that will last a hundred years, You need two pipe wrenches to adjust it. There is a locking nut tightened against the nut with the packing in it. Put a wrench on each nut and loosen them. Be sure not to twist the entire assembly because it's only held there by a rubber hose from the shaft log. When it's loose tighten the packing nut till it almost stops dripping then tighten the lock nut. The hardest part will be roving the old packing. They make special tools to get it out but I use a self taping sheet rock screw and some destist type hooks. I once straightened out a fish hook and snagged it out with the barb. Water enters the boat while working there so it would be nice to do it on land if possible. The box uses 3/16" packing and I'd use the teflon type if it needs replacement.Lot of people seem to like the dripless system. It is highly over rated, very expensive and difficult to install. Boat must be hauled, coupling removed from the shaft, $$$$$, and it won't last as long as the factory installed stuffing box
