P42 engine sump
Dec 29, 2016
36
Hunter Passage 42 Ocracoke NC
So I have the normal stuffing box and it drips a few drops a minute as it is supposed to. However the area under the stuffing box slowly fills up and then drains over the lip into the large area under the engine. I have been researching and I know that the main engine sump does not have drains so that it can contain oil/fuel/etc. But i thought the area under the stuffing box is supposed to drain. I have looked for holes/drains thinking it must be clogged but there just isn't one. In a previous post (which i am unable to find now) I thought I saw a pic showing drains on each side in the forward part of the stuffing box sump area. Anyone had an issue with this? Anyone have a pic of the drains? Manually pumping this area is becoming an annoyance. We are on the ICW heading south so mostly motoring. Thanks. Jim
Sep 11, 2011
426
Hunter 41AC Bayfield WI, Lake Superior
on our 41 there are limber holes on each side of the pan under the stuffing box. I wonder if they were never drilled out during manufacturing?
Dec 29, 2016
36
That is sort of what I am thinking but it just seems weird to me that the previous owners of the boat didn't notice over 28 years and 1600 engine hours...
I am at a marina for the day in Hilton Head SC. I'm going to pump out and clean the area and take some pics. I'd really like to know if they are just drain holes or drains with a hose or something and their location.
Likes: JamesG161
Dec 29, 2016
36
Well I drained it and cleaned it out. There are definitely no drains. Also emailed the previous owner and he confirmed that he would just manually empty it as needed. Maybe they added drains in the later years. Mine is a 96
Dec 25, 2000
5,932
That area under the stuffing box on our 1991 boat must have limber holes, since our box drips end up in the main bilge. Never paid much attention, but will check the next time to the boat. The main area under the engine does not have limber holes, but is there to collect any engine fluids for proper disposal.
Likes: HoosierSailor
Dec 29, 2016
36
I would definitely appreciate that. I have searched and searched. I can't find a drain or limber holes or anything.
Mar 6, 2008
1,340
No drain holes for my C36. I cut side of a large plastic bottle creating a deep tray that is wedge shape and is long enough to reach from the bottom of log hose to underside of the transmission, about 10 inches. It catches the drips. I empty the tray using a srynge. There is never water in the engine bilge unless I do not show up for more than 30 days. That has never happens.
Jan 7, 2011
5,585
Oday 322 East Chicago, IN
The shaft bilge on my O’Day 322 would also flow into my engine pan. I put a shallow plastic bowl under the stuffing box. Then I tried a sponge…all to try and keep water out of the engine pan.
Finally switched to a Volvo dripless seal…a game changer. Now I never have water under the engine.
Greg
Apr 21, 2017
75
Hunter 42 Passage Punta Gorda
Our 1992 Passage (hull #95) has limber holes at the foward end of the stuffing box sump area at the corners where the divider attaches. One on each side about 1/2" in diameter.
Dec 29, 2016
36
Thanks Jim. Mine is a 96 and I guess they forgot them on my boat.
Boog
Sep 20, 2017
8
Hunter Passage 42 Seattle, Shilshole marina
My P42 has the same holes Jim_H42 described. Looks like they were sloppily drilled or punched. I don't think there is any hoses or anything under them. Since my bilge is usually dry and I like to keep it that way, I put a big sponge under the stuffing box which catches most the water each trip. Then I just squeeze it out.
