The propane bin drain thru-hull is located aft of the rudder at the bottom of the hull, midline right above the water line. Mine is cracked needs to be replaced. Of course, after checking it out today from below-decks (and peering beyond my autopilot ram), it looked like it would be impossible to reach from the starboard side unless you have arms that are 4 1/2 feet long and from the port side unless you were the size of a four year-old. (Hmmmm. . .) Has anyone replaced this thru-hull fitting and could provide me any suggestions?
Thanks!
Thanks!
