G
Gary
1987 H28.5 / Yanmar 2GM20FMotored a solid 11 hours at 2800 rpms couple months ago without incident and put it in its slip where it remained till yesterday. Motored out of the harbor about 10 minutes and then sailed about 2-3 hours. Coming back into the harbor, started the engine and within about 2-3 minutes the high temp alarm sounded. Today, I found the coolant completely full, the raw water strainer slightly dirty, but not near enough to cause problem. The impeller and its bearing was replaced last week. I also scraped quite a nice family of barnicles off the prop and shaft. Then I started the little girl and.....for the life of me.....since the discharge is below the waterline, I can't tell if water is being discharged......or blowing air and the resulting splash from the big "bubble" makes it look as if water is coming out. I held my fingers over and in the outlet and just can't tell. Don't really know how much water is suppose to come out, but it doesn't feel like any. Any help appreciated!
