Jim N.
I have an 1981 Hunter 30 that always starts well when the engine is cold. However when the motor is hot I get the idiot light that it is overheating and not pumping water. By the time a service man checks the boat over it is pumping fine. It only does this when it is starting never while running. It was suggested that I may be draining my water line and getting air into the impeller. A mechanic told me to start the engine at close to full throttle to generate as much initial vacuum as possible then throttle down after the motor starts. Any advice appreciated.
