Overheating MD6A??
Oct 30, 2019
34
Three times in the last two weeks, our engine has unexpectedly overheated after a period of 5-6 hours continuous and troublefree running. There appears to be no restrictions to the seawater inlet, the impellor pump seems fine and I've boiled-up the thermostat at that seems to be working OK too. Any ideas/suggestions?
bv0820
Jun 24, 2003
66
I just had a related experience. My solution was to remove the thermostate housing and located that the "small" inlet was partially blocked. Cleaned that out. Removed the impeller and backwashed. My thermostate was also very stiff. Fixed and reassembled...also used some liquid gasket along with the regular material. Let that set up over night. Next day started up and have excellent water flow out of exhaust.
Amazing what a little restriction can do.
Good luck
Bob Vogel , Laughing Gull
Nov 8, 2001
1,818
Hi Bob
Clogged arteries! Check teh manifold as this is the usual cause. 4 x
long bolts but be careful with the gasket as tehy cost a fortune (£50).
Take manifold off and clear all clogging-up.
Cheers
Steve Birch (Technical)
Oct 19, 2019
921
Albin Vega 27 Limerick
Steve's suggestion worked for my MD6A as well.
John
Steve Birch said in an email sent on 09/10/06 16:42 that:
Oct 31, 2019
230
Robert, what do you mean by "backwashed" ? Cheers, Trevor (Mystic Rose
- V2915)________________________________
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On
Behalf Of Robert Vogel )
Sent: October 9, 2006 10:58 AM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Overheating MD6A??
Good luck
