Overheating issues, it can't be this hard!
Really small ones probably work themselves out also I am rough guessing....
No, they don't. There is nowhere for them to go. It is what in engineering is called a CLOSED system. That is why the air needs to be VENTED OUT, as completely as possible. Without getting into the scientific details, tiny air bubbles can and will be pushed through by a pump if these tiny bubbles are a small percentage of the liquid volume. Water pumps cannot pump air. Period. That's why your engine overheats if there is an air bubble in the FRESHWATER coolant side. The freshwater carries the engine heat to the HX where the seawater cools it and returns it to the freshwater loop via the freshwater (coolant) pump. If that pump hits a block of air, movement of even the liquid stops.
Take a look at the freshwater coolant loop on your engine to understand, if you don't already. Here's a good example:
Likes: Ken13559
RoyS
Jun 3, 2012
1,742
Additionally to what Stu has stated, your thermostat may end up in the air bubble. If that happens your engine will overheat due to the thermostat never opening.
Jul 5, 2011
754
Oday 28 Madison, CT
OK, interesting. So flipping the discussion, if one is running at normal temps (within spec of Mfg), it is unlikely there is any air in the system.
Jan 7, 2011
5,855
Oday 322 East Chicago, IN
I was motoring for an hour or more this weekend, and took the opportunity to take temperature readings on my Yanmar 2GM20F motor.
I was running at about 3000 rpm’s, flat seas, pushing my O’Day 322 at 6 knots.
I used an infrared thermometer and took readings in various areas of the engine:
Exhaust manifold 375 F
Heat Exchanger. 156 F. This was by the neck, but on the actual H.
Mixing elbow. 135 F. Near the top, after the water inlet
Valve cover. 165 F
Thermostat housing. 165 F at least I think that it was the thermostat housing area.
So, when people talk about the engine temperature, where are they measuring the temp specifically?
On the positive side, my traditional stuffing box appears to be pretty dialed in (with GFO packing) with no noticeable water spray at 3000 engine RPMs and the shaft and stuffing box were cool enough that I could grab it (100 F or so).
The little engine ran well…
Greg
Likes: Ken13559
Jul 5, 2011
754
Oday 28 Madison, CT
For me, at the temperature gauge....
RoyS
Jun 3, 2012
1,742
Your thermostat is supposed to keep your engine temperature at the thermostat's listed temperature value. When the coolant passing by the thermostat reaches the thermostat setting (say 160F) it opens and redirects the coolant to the heat exchanger to be cooled before returning to the engine. If the coolant passing by the engine thermostat is below the thermostat's setting then the device remains closed and sends the coolant back to the engine block. This is called by-pass. Eventually the thermostat modulates the coolant flow to result in your engine running at the thermostat setting. Somewhere on your engine is an over-temperature sender. Aim your probe at the casting that the sender is screwed into and that should give you your true engine temperature. If you ever decide to add a temperature gauge, put the gauge sender there.
Oct 26, 2008
6,370
Catalina 320 Barnegat, NJ
So, my understanding is that the standard Yanmar panel doesn't include a temp gauge and the temp switch is placed at the casting that houses the thermostat. P.O. installed the temp sender on a tee fitting that branches to the water heater. He mentioned to me that the temp gauge always reads a little cooler than the true engine temperature - I typically see 160 when warmed up and running. I'm assuming that the switch engages the buzzer alarm for over-heating. I'm more inclined to hear an alarm before I actually look at the gauge. The gauge is at ankle level and I'm not inclined to crawl down to the floor to look at it frequently. Would you say that I should leave the switch and sender in the current positions or swap them so that the gauge is reading true engine temp. The alarm might go off a little late ....
Engine is 3GM30F
RoyS
Jun 3, 2012
1,742
Scott, hard to tell how exactly your system is plumbed from the photograph. It appears that the two senders would see the same temperature unless there is some other device modulating the water line to the water heater. If it were me I would leave the switch where it is. You are fortunate that you can hear the overtemp alarm. I can barely hear mine with the engine running. I added a boat horn in parallel to the alarm and mounted it under the helm seat so I would be sure to hear it. Last time it went off I nearly jumped overboard, clutching my chest.
Oct 26, 2008
6,370
Yes, it seems to me that that both senders are reading pretty close to the same temp - the plumbing at the Tee is coming directly off the water pump housing. I don't know if I can hear the overtemp alarm! I don't think it has been activated in the past 2 seasons.
JFDuBu
Jun 19, 2023
1
Goman Express Express 35 QDNYC
This is a bit of a bump and story about my over temp issue. After I install a complete new wiring harness for my 30gm30 I started getting all my warnings to work. (longer story). After I replaced my temperature switch, last fall, i started getting the warning light. My gauge always read great, 160-170 degrees. This year the light comes back, I do all the normally stuff, clean the strainer, check impeller, all good but still have the light. Come to find out there are 2 different switch's, one rated at 65 C and one at 95 C. Guess which one I had. My system has been working fine all along. New switch on order. My guess is for raw water cooled engines they use the lower switch. I have fresh water cooling. Can anyone confirm this?
John
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Another item to consider when troubleshooting overheat conditions is the zinc in the heat exchanger. The OEM heat exchanger on the Universal M25 only had a cap at one end. The zinc was at the opposite end. As zincs deteriorate, and erode, particles of them collect in that closed end and can eventually restrict the flow of raw water. Sometimes they can be fished out through the zinc fitting opening with a piece of stiff wire but the HX may need to be removed to fully clean it. Ideally get a new larger HX as the OEM 2 inch diameter was considered very marginal for adequate cooling of that engine. The ODay 30 likely used the same equipment. A 3 inch diameter HX is available by aftermarket suppliers but the mounting bracket needs to be bent a little to fit the curvature. I did this by putting it in a large vice and squeezing it to expand the radius of the bracket. You can also mount the HX externally to the engine on a bulkhead as it's function does not require direct mounting on the motor.
754
Oday 28 Madison, CT
Yes, Mr. Cool has HX's with caps at both ends. I had a broken off piece of anode stuck and pulling that "second cap" enabled me to quickly fish it out and get my engine temp back in line.
