Overhead Light Switch for a 376
Jan 4, 2016
4
Hunter 376 Marina Del Rey
I have what should be a very easy question...
I can't seem to locate the light switch that controls the overhead recessed lights on my 1996 Hunter 376. The boat is fairly new to me and I've looked all over trying to find the switch. Probably something I should have figured out during the test sail or survey...
Thanks in advance.
Jun 4, 2004
255
Hunter 376 Annapolis MD
The switch is on the wood panel wall to the left of and about 2 ft above the chart table.
allan
Jan 4, 2016
4
Thanks, Allan. That's what I was afraid of. That switch only turns on the courtesy lights in the kitchen for me. I'll have to do some investigation and see whether all 3 bulbs have burnt out or if this is a wiring issue.
Apr 11, 2010
998
Hunter 38 Whitehall MI
Another thing to check is that if your lighting is wired similar to what our 38 has, there is a switch that turns the ceiling lights on and then each fixture has its own switch integral in the fixture. That switch might be turned off.
