Outside Shower
Todd
I am curious to know how hard it is to install an outside shower head in the cockpit. The head of a catalina 30 just is not enough room to shower comfortably and i would like to install one in the cockpit. How would I hook it up so both hot and cold water could be used, and also where could i purchase such an item, thank you
K
Keith
shower in cockpit
I put one in my 88 30. It was not a hard project to once you get the parts and decide to start cutting the hole for the faucet. I placed mine on the back side of the "T" behind the wheel on the port side. The plumbing was easy to pick up by the water heater and I put ball valves on both so that I can shut that part of the system off for easier winterizing. I think you can find the faucet and box in a one piece unit in most any of the marine catalogs. It is a very worth while project and one you will say "why didn't I do that earlier?" Just make sure you check the measurements of the unit plus the flange before you start cutting. It is a tight fit but do able. Put some masking tape under the shoe of your saber saw before cutting to keep prevent scratching the fiberglass around the cut. Happy showers!
jchealey
cockpit shower
I have installed one in my port side coaming about 14 inches from the transom the unit i bought was a standard Attwood unit purchased at West Marine about $110 has both hot and cold water and retractable showerhead with a 6 foot hose.Easy enough to tie into existing h/c water lines.
