Rodd C.
I need to replace the outhaul on my 86 C36 and I'm wondering if it is a rope to wire splice or an eye to eye splice inside my boom. I beleive it is the original outhaul from the factory. If it is a rope to wire splice I should be able to use the old outhaul as a snake to pull the new one through. If it's eye to eye I'll have to remove one of the fittings on the end of the boom. I dread this because I'm sure the galvanic corrosion has seized all four of the screws holding the end fitting on. Any input would be great. Thanks,Rodd C.
