Outcome: Will A Generic GPS Antenna Do For An Older Chartplotter ....
Jun 21, 2007
2,118
Does anybody have experience with generic antenna replacements for older chart plotters?
Installed in my boat when I bought it in 2007 was an early 2000's Standard Horizon GPS chart plotter CP150c. It wouldn't acquire the satellites. I tracked the problem down to a bad coax cable solder connection within the antenna. Several years ago, same fault occurred again. I restored function by re-soldering again. Then recently same issue. But I was a bit careless this time, plus one too many re-solderings. The circuit board in the antenna is now physically kaput. The head unit is still powering up fine. I have it linked to my VHF and ST4000+ autopilot. So am not inclined to give up on my chart plotter without a fight. So what to do?
On line, I am seeing listings for many "active" generic GPS antennas that have essentially the same specification as shown in my CP150 owner's manual. Mainly 3.0 - 5.0 volts (I did measure the volts today from the head unit antenna out. Yes = 5.0v). The generics have the same SMA connector, same RG174 cable type, same receiving frequency, etc, as in the CP150 owners manual.
Most are priced around $10 including shipping. From my perspective, certainly worth the risk of buying . A few "hits" for CP150 specific antennas are ~ $150.
7,733
Alden 50 Sarasota, Florida
GPS antennas differ only in style and color. Powered ones similarly. Some manufacturers try to make their's unique only to perpetuate sales so if you found a like-powered one, you should not have any problem.
Jun 21, 2007
2,118
Just thought to report in case someone else has need of the info:
Yes, the generic gps aftermarket antenna I ordered works! Picks up more satellites and does it quicker than before. Maybe the difference between 2002 vs 2015 technology.
Likes: LloydB
