Outboard transom board dimensions
Jun 18, 2021
8
Hunter 23.5 N/A
Does anyone know the dimensions of the Hunter 23.5 outboard transom board. I need to replace mine and would like to precisely cut and drill the bolt holes in my shop as the boat is not nearby at this time.
-na -NA Anywhere USA
The outboard motor bracket is bolted into the transom which has metal implanted in the fiberglass. Hunter used 5200 sealant. Sometimes the thread in the bolt holes were stripped out requiring larger bolts or simply securing with longer bolts bolted inside the boat. I would suggest waiting until you are back at the boat to get the bracket.
You may want to purchase from the forum store metal stainless steel straps to extend the motor bracket outwards which will extend the motor outwards. The hanger or outboard motor brackets will fit into the present holes on your boat which are on the 240 and 260.
send me you phone number via private message on this site. I am a retired Hunter dealer known for my knowledge of Hunter trailerable sailboats
Dave
